adding widgets to downloaded Apps
496
11-30-2012 11:13 AM
ErikBlake
Is it possible to add widgets to a downloaded app. For example I downloaded "legend_main" app. But I need to be able to turn my layers on and off. Can i add a widget folder and then also add widget commands into the index.html.
Erik
MikeMinami
Esri Notable Contributor
I am not familiar with the application. However, if you downloaded it and it contains the source code, you should be able to modify it any way you want, as long as you know the development environment. If you need coding help, I'd suggest posting in the appropriate forum for JavaScript, Flex or Silverlight development.
Mike
