ExportToPDF script : allow overwrite validation
1700
11-22-2012 04:48 AM
MaximeDemers
I have a simple script that Export to Pdf the current Page_Layout of a mxd. I want to use it in a toolbox with a path parameter for the output. I have an error when I select an output that already exists. I suppose I have to code something about allowing overwriting in the validation of this parameter but I cant find any info about that.
Anyone can help?
MathewCoyle
Honored Contributor
Oh I see, I was under the impression your errors were showing up before you ran the tool. I assume in your script pdf is the variable of the path and name is the name of the pdf you want to create? Something like this should get you going.
import os import arcpy  mxd = arcpy.mapping.MapDocument("CURRENT") pdf = str(arcpy.GetParameterAsText(0)) name = str(arcpy.GetParameterAsText(1)) res = int(arcpy.GetParameterAsText(2)) quality = str(arcpy.GetParameterAsText(3)) path = os.path.join(pdf, name) if os.path.exists(path):     os.remove(path) arcpy.mapping.ExportToPDF(mxd, path, "Page_Layout", resolution=res, image_quality=quality)
MathewCoyle
Honored Contributor
You shouldn't be getting an error. It should just notify you that the file already exists and if you want to replace it. If you want you could just process it silently in the script by setting your parameter of your output PDF to a folder and specify the name in your script while handling if the pdf already exists.
Edit: You could also just specify your parameter as input instead of output. This will allow you to take the path as a string and validate on that in your code.
MaximeDemers
Thank you for your answer,
Unfortunately, even with a Parameters with Data Type: Folder, I have the same error. It said that the folder already exist. Error 000725
When I specify the folder parameter as an input, i have an error saying that the file doesnt exist.
MathewCoyle
Honored Contributor
MaximeDemers
Thank you very much! Thats perfect!
