Add Numeric Data as a Label
4642
10
11-13-2012 08:15 AM
DonaldLund
I am just starting to work with ArgGIS Online and was wondering if there is a way to add numeric data as labels to a map. This is easily done within ArcGIS Desktop. For example, you can label a county with the county name or you can change the label to area, population, etc. I don't see this option with the Online product. Does this capability not exist? Can you plot text strings as X,Y data? I don't see this as an available feature.
Thanks.
SarahO_Rourke1
Check out this resourse on adding labels to ArcGIS online. I've only tried it for a few features and it seems to work okay as long as you get them placed properly in arcmap.
http://blogs.esri.com/esri/arcgis/2011/11/21/adding-labels-to-arcgis-online-web-maps-part-1/
MikeMinami
Esri Notable Contributor
There is no labeling ability.
Mike
DonaldLund
Mike
What about adding a layer that contains graphic text? I've seen something about that in a google search. Is that a possibility?
Don
MikeMinami
The ArcGIS.com website doesn't support adding text as graphics. However, you can use another application, ArcGIS Explorer Online to do so. http://www.arcgis.com/explorer. Sign in and you should be able to open any web map you created in ArcGIS.com.
Mike
DonaldLund
Mike
Thanks Mike. I'll give it a try.
DonaldLund
Mike
Mike,
I looked at this and I can see how it is possible to manually add data values as text, but I have too many to do them all manually. Is there a programmatic way this can be done, such as importing a kml file with text labels and lat/lon xy coordinates for the label?
Thanks.
Don
SarahO_Rourke1
MikeMinami
Don,
I don't know any other way...the KML pathway seems interesting.
Mike
DonaldLund
Thanks Sarah. This is exactly what I was looking for.
I wish I didn't have to jump through all the hoops, but at least I CAN jump now.
I think this is a short-sighted design issue with ArcGIS Online. I can't believe there aren't more people out there that want to plot numerical data labels on their maps.
I'm also a little bewildered that it was so hard to find this information.
Anyway, thanks to you, I don't have to give up completely on ArgGIS Online now.
Regards,
Don
TomScharmen
Here is a somewhat complex process that allows you to add labels without having to create a tile map service. If the search function on the forums was worth a damn, I might have found this by myself.  But ESRI tech suport (Jegan) found it in a few seconds.
Adding labels to ArcGIS Online web maps: Part 1
Adding labels to ArcGIS Online web maps: Part 2
