Area of a raster in Python
2390
11-08-2012 05:01 PM
NataliaOcampo
I have a file full of rasters with a Value of 1, the rest is NoData.
I need to extract the Count for each raster, to then calculate the area, by multiplying by the cellsize.
I was trying to do this with the Get Raster Properties tool, using UNIQUEVALUECOUNT as the property type yin the script but instead of returning the count, it would return a 1.
  count = arcpy.GetRasterProperties_management (fileName, "VALUETYPE")
Is there an automated way to extract the count from a raster, using Python????
I would really appreciate your help.
thanks!
MarcinGasior
There's no simple property of COUNT for raster values.
It can be read from raster attribute table with a search cursor in this way:
import arcpy,  inRaster = r"C:\test.gdb\myRaster"  # Build attribute table if needed #arcpy.BuildRasterAttributeTable_management(inRaster, "OVERWRITE")  # Create a search cursor for desired raster VALUE sCur = arcpy.SearchCursor(inRaster, '"VALUE" = 1') for row in sCur:     cellCount = row.getValue("COUNT")     print cellCount
MarcinGasior
NataliaOcampo
Thank you so much!
This was very helpful!
