Producing a Choropleth Map Using My Own Data
2383
10-25-2012 11:15 AM
ShirandeepJuttla
Hello all,
I am student in my final year, and for my dissertation, i am looking at rainfall data since 1900 in the UK...
I have all of this data on an Excel File.
I would now like to create a Cholopleth map with this data, if humanly possible.
As far as i am aware, i need to create an ODBC source then reformat the data, then connect it from Arc Cat.
I have created the ODBC file but reformatting it did not work.
Any ideas on how to create this Cholopleth map?
p.s The data i have is Monthly data from 1900.
LucasDanzinger
Esri Frequent Contributor
It all depends on what geography your rainfall data were collected in (i.e. zip code, county, some other boundary). You will need to get a shapefile/feature class of the boundaries in the map. Once you have this, you can add the Excel document to the map. Then, you will need to do a table join to get the data from the Excel spreadsheet into the shapefile. You can then symbolize your shapefile based on the data in your Excel spreadsheet.
