Error response when running OD Cost Matrix solver through SOAP API
668
10-22-2012 01:44 PM
Patrick_Numainville
(Cross-post from SOAP API forum, not sure which will give me a better response)...
I'm running the OD Matrix Solver using the SOAP API but I have run into an issue.
The request is submitted and seems to be processed successfully by the server however the result is never returned. My client application received a Runtime Error from the ArcGIS Server(10.0) as soon as it finished processing.
[TABLE="class: cms_table"][TD="class: cms_table_list-item"]INFO2[/TD]
[TD="class: cms_table_list-item"]String request succesfully processed. Response size is 4954286 characters.[/TD]
[TD="class: cms_table_list-item"][/TD]
[TD="class: cms_table_list-item"]INFO3[/TD]
[TD="class: cms_table_list-item"]NALayer [OD Cost Matrix]: Generated 475 x 475 x 2 OD Matrix.[/TD]
[TD="class: cms_table_list-item"]NALayer [OD Cost Matrix]: Solve completed.[/TD]
[/TABLE]
[TABLE="class: cms_table"][TD="class: cms_table_list-item"]INFO3[/TD]
[TD="class: cms_table_list-item"]NALayer [OD Cost Matrix]: Loaded 475 Destinations.[/TD]
[TD="class: cms_table_list-item"]NALayer [OD Cost Matrix]: Loaded 475 Origins.[/TD]
[TD="class: cms_table_list-item"]NALayer [OD Cost Matrix]: Copied network analysis context.[/TD]
[TD="class: cms_table_list-item"]String request received. Request size is 412511 characters.[/TD]
[/TABLE]
HTTP Response:
Server Error in '/ArcGIS/Services' Application.
Stack Trace: [HttpException (0x80004005): Thread was being aborted.]
I though the issue might be the request/response size (4954286 > 4096000 ) so I increased MaxRequestSize on the ArcGIS/services web.config and recycled the app pool but that didn't solve my issue.
Smaller solver requests work fine.
Any feedback would be appreciated
Patrick
