PROBLEMS IMPORTING ARCGISSCRIPTING
3201
7
10-10-2012 06:27 AM
RoyMartinez1
I'm learning how to code in Python but I'm not able to import the ArcGIS modules either in IDLE or PythonWin when I perform the following.  By the way I'm using ArcMap 9.3.1, also the file arcgisscripting.pyd is in my C:\Program Files\arcgis\Bin folder
#Import modules
import arcgisscripting, sys, os
Code resulted in the following error message:
ImportError: Module use of python25.dll conflicts with this version of Python.
I have done the following to check where python is pointing
import sys, pprint
pprint.pprint(sys.path)
which resulted in the following:
'C:\\Program Files\\Python26\\Lib\\idlelib',
'C:\\Program Files\\ArcGIS\\bin',
'C:\\Windows\\system32\\python26.zip',
'C:\\Program Files\\Python26\\DLLs',
'C:\\Program Files\\Python26\\lib',
'C:\\Program Files\\Python26\\lib\\plat-win',
'C:\\Program Files\\Python26\\lib\\lib-tk',
'C:\\Program Files\\Python26',
'C:\\Program Files\\Python26\\lib\\site-packages',
'C:\\Program Files\\Python26\\lib\\site-packages\\win32',
'C:\\Program Files\\Python26\\lib\\site-packages\\win32\\lib',
'C:\\Program Files\\Python26\\lib\\site-packages\\Pythonwin'
I would greatly appreciate it if someone could provide some details on how I can fix this problem.
DanPatterson_Retired
You should have installed Pythonwin from the ESRI ArcGIS installation CD, it sets up the appropriate file associations and the correct version of Python and Pythonwin for the version of arcmap that you are using.
RoyMartinez1
This is my work computer which came with Python 2.6.5 preinstalled when it was assigned to me.  Maybe I need to uninstall and reinstall Python.
You can have concurrent versions of Python running ... but that would be a good start
RoyMartinez1
What I noticed in the error message from my original post, is that when attempting to use python 2.6.5 it was attempting to call the Python25.dll.  Shouldn't it be calling something like Python26.dll?  Also, is python 2.6.5 compatiable with ArcGis 9.3.1?
MathewCoyle
Honored Contributor
I do not believe so. You will need Python 2.5.x
ThaiTruong
Even though 2.6 is not officially support, you can try to make it works with 9.3.1 with this configuration:
  1. After install Python 2.6.x, download and install its corresponding pywin32 from this site
  2. Get this arcgisscripting.py script written by Philippe Le Grand from this old thread and place it into C:\Python2.6\Lib\site-packages
RoyMartinez1
Thank you all for the helping hand.
