string.format  escaping {?
23825
10-03-2012 10:03 AM
KevinBell
How does one use { and } in a string that is being formatted?
s = 'I am going {nuts}'.format(nuts= 'crazy over this') #except my string would have curly braces in it.
If using the curlys in the string the format method thinks I want to swap something.  Is there a way to escape it?
Thanks!
JasonScheirer
Esri Alum
{{ and }} give you single curlys.
JasonScheirer
Esri Alum
ClayPerry
If you just want a string with the value: 'I am going {nuts}'.format(nuts= 'crazy over this')
Try encapsulating it in double quotes like this:
s = "'I am going {nuts}'.format(nuts= 'crazy over this')"
Or you might need to somehow concatenate the string like this:
s = 'I am going {wild} ' + '{nuts}'.format(nuts= 'crazy {nutty} over this') + ' for real!'
print s
'I am going {wild} crazy {nutty} over this for real!'
curtvprice
Neat, Jason!
Interactive Python example:
>>> 'I am going {{{nuts}}}'.format(nuts= 'crazy over this')
'I am going {crazy over this}'
