Make SearchCursor from Excel table?
709
10-01-2012 03:08 PM
RobertMartin2
Hi all,
I am having a heck of a time making a SearchCursor from an Excel table with a WHERE query. I made a test table with just one column called NAME and a cursor as follows:
where = '\"NAME\" = \'Tom\'' rows = arcpy.SearchCursor("Sheet1$", where)
This works fine. But when I loop over the rows and print NAME nothing happens (I'm guessing no rows satisfy the query, though the data is there). Conversely if I change the statement to:
where = '\"NAME\" <> \'Tom\''
it returns ALL rows. Obviously the WHERE clause is not working, but it looks fine to me and I don't get any syntax errors. Can anyone think of what might be happening here? Maybe an Excel peculiarity?
Thanks!
JakeSkinner
Esri Esteemed Contributor
Try placing the field name in brackets.  Ex:
where = "[First Name] = 'Tom'"
JakeSkinner
Hi Robert,
Try changing your where clause to:
where = "NAME = 'Tom'"
RobertMartin2
Thanks Jake, that did the trick for that table. The only issue is that my actual data has spaces in the column names, so I think I need the quotes. Any thoughts on how to incorporate those?
I tried something like
where = "\"FIRST NAME\" = 'Tom'"
and the cursor generated fine, but with no rows.
JakeSkinner
