arcpy will not import into pythonwin
840
09-26-2012 06:54 AM
jasonlewis2
When i enter the import arcpy command in pythonwin I get this error:
  File "<interactive input>", line 1, in <module>
ImportError: No module named arcpy
Can anyone tell me how to fix this issue? Thanks.
JakeSkinner
Esri Esteemed Contributor
Hi Jason,
Python looks in the directories that are part of the module search path. These directories
are listed in the sys.path variable from the sys module.  To list where  the Python looks for modules, print out the value of the sys.path  variable. For example, type the following in pythonwin's interactive window:
import sys
print sys.path
By default, arcpy's default location is:
C:\Program Files (x86)\ArcGIS\Desktop10.1\arcpy
or
C:\Program Files (x86)\ArcGIS\Desktop10.0\arcpy
If the path isn't there, try adding the path using the sys.path.append method.  Ex:
 sys.path.append(r"C:\Program Files (x86)\ArcGIS\Desktop10.0\arcpy")
