calculated field with python
2897
09-26-2012 02:38 AM
ben_abdallahmhd
i would reclass an attribute ALTITUDE (float)
i use calculated field with python an i write this code of script
def reclass(ALTITUDE):
if ALTITUDE == 39,99:
  return 40
ALTITUDE=
reclass(!ALTITUDE!)
--> ok
but this error 000989 appear
where is the false please
JasonScheirer
Esri Alum
Python, like most programming languages, uses the period as the decimal separator regardless of what your local language uses.
Try this:
    if ALTITUDE == 39.99:
        return 40
    else:
        return ALTITUDE
JasonScheirer
Esri Alum
Try this:
        return 40
    else:
        return ALTITUDE
ben_abdallahmhd
thank you jscheirer it work 🙂
