How to create in memory layer and how to visualize these?
1187
09-25-2012 07:07 PM
SteffanVoss
At the moment I am building an add in in C#.
My goal is to use the data of an existing feature layer and to perform some calculations with this data.
That works fine...
Now I want to visualize the new values with a feature renderer like the UniqueValueRenderer.
To achieve this I want to create an in-memory layer, which is a merge of the existing layer and my new data.
I already found the InMemoryWorkspace but the doc says I can not create feature datasets within.
Is there a way to do this on the fly or do I have to copy the old one add my column(s), add it to the TOC and later on use one of therenderer?
DuncanHornby
MVP Notable Contributor
If I've understood you correctly you have a layer that you have done some calculations on and you want to merge this layer with a second layer into a third "in memory" layer and then display this third layer?
You should be able to do this with an in_memory workspace. When you use the merge tool the output is a FEATURECLASS this is not a FEATURE DATASET which is a sort of "folder" in a geodatabase. As you noted an in_memory workspace cannot support a FEATURE DATASET but it will hold a FEATURECLASS. From this you can write code to create a FeatureLayer and render as you wish then add that to the Map Document (IMap).
Duncan
DuncanHornby
Duncan
