increment duplicate records based on a field
1976
09-19-2012 07:59 AM
NancyMarth
Looking for some simple code to run either in Field Calculator (preferred) or in a python script on a table to create a field and add incremental numbers to that field based on repeating values of another field, for all records.  I've already permanently sorted the table, which I need to do before incrementing the duplicate records.  I can create the field no problem to minimize steps necessary, if someone can provide the basic code for the increment based on a field.  Thanks.
Example table:
FieldA     Dups (created)
3            1
3            2
3            3
1            1
1            2
1            3
1            4
8            1
8            2
JakeSkinner
Esri Esteemed Contributor
Hi Nancy,
Try the following in the field calculator:
d = {}
def findDuplicates(inVal):
  try:
    d[inVal] += 1
    return d[inVal]
  except KeyError:
    d[inVal] = 1
    return 1
findDuplicates(!FieldA!)
Be sure 'Python' is checked within the Field Calculator.
AlessandroCinnirella
i made it too quickly. test it!
a = [3,3,3,1,1,2,2,5,6,8,8] #the input values
b = [] #temp list
c = [] #duplicate value list
for i in a:
    if len(b)< 1:
        b.append(i)
        c.append(len(b))
    else:
        if i in b:
            b.append(i)
            c.append(len(b))
        else:
            b = []
            b.append(i)
            c.append(len(b))
hope this helps.
ciao,
AC
markdenil
I think you needn't have sorted the table.
If you build a list of unique values for FieldA
and then itterate through the list to
make a layer (or table view), in turn, of the records with that value as the FieldA value
Run an update query on the layer or view
incrementing a counter and assigning the counter value to Dup field
Then blow that layer away, and make a layer of the next FieldA value in the list.
for each new layer, reinitalize the counter, so the first instance is 1 (or 0).
EDIT -> 3 simultaneous replies! HA!
NancyMarth
Jake,
This works perfectly.  Thanks very much.
