I am loading map in my app from VPN services. The map s are working fine with simulator but in device map is not loaded it gives
error Error Domain=org.brautaset.JSON.ErrorDomain Code=3 "Unrecognised leading character" UserInfo=0xa71560 {NSLocalizedDescription=Unrecognised leading character ...
is it problem of map extent or what please tell me.........
If it is going to ask for VPN credential every time you hit the map service URL then it's not going to work. Because SDK has no way to know. It only tries to connect to the URL host and it's not reachable because VPN is not already connected. Hope this helps!
When device is connected to vpn & I open the browser then it ask for vpn credentials after entering those I am able to access those services in browser.
So every time you try to connect to your service, it asks VPN credential? Isn't VPN already connected? Don't you see VPN symbol on your devices top bar? What kind of VPN are you using?
You should use app like Junos Pulse to connect to VPN.
I have used the CiSCO VPN client & seted the proxy address still it is asking for credentials, Every time when connected to vpn. Also map is not displayed in device
Ya I am using 'Cisco AnyConnect' for VPN connection. When I connect to VPN only for first time it asks for credentials. And tell me way to display the map in device.
