Cad inserted in layout
6118
09-07-2012 06:13 AM
hollyserge
I have a Autocad dwg titleblock that I need to use in Arcmap can any one tell me how to import it into the layout view so I can use the dwg titleblock
ManuelRodriguez2
Any help on this would be greatly appreciated.
JustinOdell
If you have the .dwg file, you can load it into ArcMap.
Set your page layout size and orientation as per the dwg.
Then convert the relevant titleblock pieces (i.e. the polylines) to graphics by right clicking on the feature in the Table of Contents.
In Data View, turn off the original dwg layer, select all the graphics and click copy.
Go into Layout View and paste outside of the data frame.  The features should appear close to the page extents.
Some minor tweaking may be required to fit the features to the page.
WesMiller
It may be easier to create a new data frame, insert your cad file and overlay the 2 data frames in your layout view
