Date query on File GDB
1393
08-31-2012 10:08 AM
KevinBell
I'm getting aggravating results trying to query a date time field in a fgdb...
If I use this:
"gpstime" > date '2011-06-14 10:00:00' AND "gpstime" < date '2011-06-14 11:00:00'
in the select by attributes dialog in arcmap it works fine, but using it as the whereclause in
arcpy.SelectLayerByAttribute i get the wrong times.
ideas?
KevinBell
User Error!  I shouldn't program on Friday afternoons!  I just had a problem buried in the routine that builds the query.
KevinYanuk
If I use this:
ideas?
There might be an issue with the quotations.  You could try to set it as a string variable, and passing the variable as the query:
query = "\"gpstime\" > date '2011-06-14 10:00:00' AND \"gpstime\" < date '2011-06-14 11:00:00'"
arcpy.SelectLayerByAttributes_management(lyr, "NEW_SELECTION", query)
edit:  notice the slashes I used in the query string to ignore ending the full string
KevinBell
I am actually passing it in as a variable.  I build the string up programmatically and print the whereclause using addMessage and this is how it prints out, which works if using the query builder.
KevinBell
