install arcgis sdk wrong
1331
08-30-2012 04:36 PM
zhangbo
i use xcode 4, and install arcgis sdk, compile the mapviewdemo, it is ok.
but i compile the graphic demo that download from arcgis resources, it display following error:
framework cant not found.
Linker command failed with exit code 1(use -v to see invocation)
i add arcgis.a in my library of build phase, it is also error. who know what's wrong?
NimeshJarecha
Please go through this document and make sure that your project is configured correctly.
Regards,
Nimesh
VIKRANTKRISHNA
Do I need to update the ArcGIS runtime SDK and follow the configuration steps. My app runs fine on ios Simulator , but gives the
error "linker command failed with exit code 1 (use -v to see invocation)"
NimeshJarecha
Yes, you should follow the configuration steps outlined here.
Regards,
Nimesh
