AssertionError from UpdateLayer when symbology_only False
3493
08-29-2012 10:14 AM
StevenHaslemore
My scenario is, I have several mxds with the same layers, different layouts, used for map templates. I updated the symbology and labeling details for a layer in one mxd and want to push it into the others.
Attempting the following workflow results in an AssertionError during arcpy.mapping.UpdateLayer()
1. save the new details as a layer file.
2. run this code
files = r'C:\Temp\Layouts'
newLyr = arcpy.mapping.Layer('H:\\GIS_LayerFiles\\WaterNetwork\\Hydrant.lyr')
layerLongName = 'Water Network\\Hydrant'
symbologyOnly = False
for r,d,f in os.walk(files):
    for fl in f:
        path = r+'\\' + fl
        if fl[-3:] =='mxd':
            print path
            mxd = arcpy.mapping.MapDocument(path)
            df = arcpy.mapping.ListDataFrames(mxd)
            layers = arcpy.mapping.ListLayers(mxd)
            for lyr in layers:
                if str(lyr.longName).startswith(layerLongName):
                    arcpy.mapping.UpdateLayer(df,lyr, newLyr, symbologyOnly)
                    print lyr.longName + " symbology updated."
I get the following error
File "<interactive input>", line 1, in <module>
File "C:\Program Files\ArcGIS\Desktop10.0\arcpy\arcpy\utils.py", line 181, in fn_
return fn(*args, **kw)
File "C:\Program Files\ArcGIS\Desktop10.0\arcpy\arcpy\mapping.py", line 1477, in UpdateLayer
assert isinstance(data_frame, DataFrame)
AssertionError
Symbology only works fine, but as mentioned I have labeling changes I want to include.
I'd much rather not update them all manually.
StevenHaslemore
It appears to be a little more particular about the dataframe when it's updating more than just symbology.
The dataframe was passing a list of one dataframe, rather than a dataframe itself, correction below.
    for fl in f:
        path = r+'\\' + fl
        if fl[-3:] =='mxd':
            print path
            for lyr in layers:
                    arcpy.mapping.UpdateLayer(df[0],lyr, newLyr, symbologyOnly)
StevenHaslemore
    for fl in f:
        path = r+'\\' + fl
        if fl[-3:] =='mxd':
            print path
            for lyr in layers:
