arcpy.mapping.ListDataFrames
5991
08-23-2012 08:10 AM
JonPedder
Morning all, this is a followup post to the thread I have going here
http://forums.arcgis.com/threads/65282-confusion-with-ListDataFrames-and-Listlayers
I'm still having a tough time understanding the ListDataFrames functionality and results. In my mind what I think ListDataFrames would give me is exactly that, a listing of data frames with the mxd. However when I execute this command I get back a listing of layers. All the examples I see in the help use [0] such as
df = arcpy.mapping.ListDataFrames(mxd, "Transportation")[0]
When I execute a line such as the above I get back a list of layers within my first layergroup.
This is probably just me not understanding python or coding very well, it's driving me a little nuts.
The objective of my script below is to save a layer of base_data from the current mxd to disk. Then look at the target mxd and see if it has a layer names Base_Data, if so remove it, then import the previously saved layer and add to the bottom of the target mxd. Then of course save.
import arcpy   from arcpy import env   # Set overwrite option arcpy.env.overwriteOutput = True   # Gather user input parameters  TargetFile = arcpy.GetParameterAsText(0)  if TargetFile > "":         arcpy.AddMessage("Target File is True")                  # from current open mxd, save base data layer file to disk         LayerFile = "./Base_Layer"         arcpy.SaveToLayerFile_management("Base_Data_Group",LayerFile,"RELATIVE")         arcpy.AddMessage("Base Data Saved as "+ LayerFile)          mxd = arcpy.mapping.MapDocument(TargetFile)         df = arcpy.mapping.ListDataFrames(mxd)         lyr_list = arcpy.mapping.ListLayers(mxd)                 for lyr in lyr_list:                 if 'Base_Data' in lyr.name:                         arcpy.mapping.RemoveLayer(df,lyr)                         arcpy.AddMessage(lyr)          path = LayerFile + '.lyr'         arcpy.AddMessage("adding layer")         addLayer = arcpy.mapping.Layer(path)         arcpy.mapping.AddLayer(df, addLayer, "BOTTOM")         TargetFile.arcpy.save()
MikeMacRae
I've had the same issue before with the index on the dataframe. it confuses me. usually I just set the mxd, loop the dataframes and then loop the layers:
        mxd = arcpy.mapping.MapDocument(TargetFile)          for df in arcpy.mapping.ListDataFrames(mxd):                for lyr in arcpy.mapping.ListLayers(mxd, "", df):                    if 'Base_Data' in lyr.name:                         arcpy.mapping.RemoveLayer(df,lyr)                         arcpy.AddMessage(lyr)
Something like that might work
MikeMacRae
JonPedder
Thanks Mike, this loop appears to work. Though I can't really tell as I can't figure out the simplest command "save"
save appears to have no paramaters
http://help.arcgis.com/en/arcgisdesktop/10.0/help/index.html#//00s30000000n000000
I'm not looking to saveacopy as i want to overwrite the original file. I have set arcpy.env.overwriteOutput = true
what would the syntax be for save?
save()
arcpy.save()
mxd.arcpy.save()
save(mcd)
I've tried them all to no avail. Silly to be hung up on something so simple
JeffMoulds
The syntax to save a mxd is MapDocument.save(). For example:
mxd.save()
In regards to your questions with ListDataFrames and ListLayers, try this:
# loop through all layers in a specific data frame:
df = arcpy.mapping.ListDataFrames(mxd, "MyDataFrameName")[0]
for lyr in arcpy.mapping.ListLayers(mxd, data_frame=df):
  print lyr.name
These topics might help as well.
http://resources.arcgis.com/en/help/main/10.1/#/ListDataFrames/00s30000001p000000/
http://resources.arcgis.com/en/help/main/10.1/#/ListLayers/00s30000002n000000/
http://resources.arcgis.com/en/help/main/10.1/#/MapDocument/00s30000000n000000/
http://resources.arcgis.com/en/help/main/10.1/#/Guidelines_for_arcpy_mapping/00s30000006s000000/
MikeMacRae
Try this:
mxd.save()
