ArcGIS 101 Server - Uninstalling the web adaptor
1298
08-17-2012 01:38 PM
harleypowers_parks
The web adaptor is a 3.5 .net web application.
should my application pool work as a 4.0 .net?
How do I uninstall the web adaptor and start over?
harleypowers_parks
Guess it helps to the read the documentation.
this forum address the issue first:
http://forums.arcgis.com/threads/45825-IIS-Web-Adaptor-Install-Error?p=225384#post225384
but my install solution:
C:\Users\Administrator>msiexec /I D:\WebAdaptor\IIS\setup.msi WEBSITE_ID=1 VDIRNAME=ags /qb
Run this command from the command line to uninstall:
msiexec /x {11CCA428-4679-4D79-ADC0-A13F43290ACF} /qb
Uninstalling additional instances silently
To uninstall additional instances of the ArcGIS Web Adaptor (IIS) silently, replace the above product code with the product code of the instance to be uninstalled. Product codes for ArcGIS Web Adaptor (IIS) instances are listed below. The product codes are listed in the same order as the instances installed on your system. For example, the first instance created is the first product code listed below:
???{F2D4A6C5-E11F-4FEF-A240-5F2BA22F6418}
???{DF32A6BA-A260-4BCD-B59A-4CEB4173B2D8}
???{0CF52969-7F17-4F85-82FF-C658F3DC5F6E}
???{8E4D5C3B-B54C-4CC5-9A5F-3EC0C6BF64F0}
???{0329B7AD-D457-42F2-B97E-BBAE26D54329}
???{38A627D7-01C7-4E3F-945D-3CD4CDF14BE5}
???{635C3AE6-F3F1-434D-B1E7-B12CE91AD83F}
???{39BE94C5-8146-4560-A54E-859979624ACF}
???{1506767A-988E-44EB-A733-E5B8BFFBE81E}
???{BFA02DB7-9E55-4179-88AC-D2C1B9802096}
harleypowers_parks
