import arcpy # set environments arcpy.env.workspace = "Path" arcpy.env.overwriteOutput = True #set parameters featureTable="Individual_catchments" baseFeature="elevation" #set cursor rows = arcpy.SearchCursor(featureClass) # loop for row in rows: #here I select the geometry feat = row.Shape arcpy.Clip_management(baseFeature, "#", "catch"+str(row.Local)+".tif",feat, "0", "ClippingGeometry")
Solved! Go to Solution.
###this first part creates individual raster files (from as single larger raster file) based on overlapping polygons import math import os import arcpy # set the workspace environment arcpy.env.workspace = "D:/path.mdb" arcpy.env.overwriteOutput = True # set the cliping regions featureClass="Individual_catchments" # set the base feature baseFeature="elevation_swiss" #create list to store catchment elevations catchmentList = [] #create table to store catchment id and average elevation CreateTable_management ("D:/path.mdb", "Average_elevations") # need to use a cursor argument since we are looking at a single table # this one assigns a search cursor to the Individual catchments table rows = arcpy.SearchCursor(featureClass) # loop to create all of my individual files for row in rows: #here we only want the geometry (shape) feat = row.Shape output="c"+str(row.LOCALITYID) arcpy.Clip_management(baseFeature, "#", output,feat, "0", "ClippingGeometry") # delete the cursor del rows ################################################################################################# ####### second part of script to take individual catchments and calculate some statistics ####### # i created this using a separate script from the first so the environments are retyped ################################################################################################# # make sure to put the module you are working with before the function (or it will spit back 'not defined') - one my biggest pitfalls ###here i want to update the catchemnt feature with additional information based on other layers import math import os import arcpy # set the workspace environment arcpy.env.workspace = "D:/path.mdb" # Overwrite pre-existing files arcpy.env.overwriteOutput = True #parameters path = "D:/path.mdb" arcpy.Delete_management("SumTable") arcpy.CreateTable_management (path,"SumTable") arcpy.AddField_management ("SumTable", "NameID", "TEXT") arcpy.AddField_management ("SumTable", "TotalCount", "LONG") arcpy.AddField_management ("SumTable", "TotalElv", "FLOAT",'',10) arcpy.AddField_management ("SumTable", "AVG_ELV", "FLOAT",'',10) SummaryT= "D:/path.mdb/SumTable" statsFields = [["COUNT", "SUM"],["ELEVC","SUM"]] #create list to point to catchment elevations catchmentList = arcpy.ListRasters ("c*") for i in catchmentList: #make sure each raster has its own attribute table arcpy.BuildRasterAttributeTable_management(i,"Overwrite") #create a new field with elevation times number of occurances (COUNT * VALUE) arcpy.AddField_management (i, "ELEVC", "LONG") arcpy.CalculateField_management(i,"ELEVC","!Value! * !Count!","PYTHON_9.3","#") temp_outtable = "outtable" arcpy.Statistics_analysis (i, temp_outtable , statsFields) #python's tedious way to get data from a table rows=arcpy.SearchCursor(temp_outtable) #this 'points' to the first row row=rows.next() #this 'points' to the field print row.SUM_COUNT,"_",row.SUM_ELEVC # Create the insert cursor and a new empty row rowInserter = arcpy.InsertCursor(SummaryT) newIncident = rowInserter.newRow() # Populate attributes of new row newIncident.NameID = str(i[0:7]) newIncident.TotalCount = row.SUM_COUNT newIncident.TotalElv = row.SUM_ELEVC newIncident.AVG_ELV = row.SUM_ELEVC / row.SUM_COUNT # Insert the new row into the shapefile rowInserter.insertRow(newIncident) # delete catchment specific search cursor and temp sum file del row del rows arcpy.Delete_management(temp_outtable) # delete the insert cursor del rowInserter
feat_id = row.FID #or however you want to uniquely identify a given polygon) qry = """ "FID" = """ + feat_id feat = arcpy.MakeFeatureLayer(featureClass,'feat_lyr',qry) out_rast = "catch" + str(row.Local) + ".tif" arcpy.Clip_management(baseFeature, "#", out_rast,feat, "0", "ClippingGeometry")
import arcpy # set environments arcpy.env.workspace = "Path" arcpy.env.overwriteOutput = True #set parameters featureTable="Individual_catchments" baseFeature="elevation" temp_featureTable = r"in_memory\temp1" temp_baseFeature = r"in_memory\temp2" temp_featureClass = r"in_memory\temp_fc" temp_layer = r"in_memory\temp" arcpy.MakeFeatureLayer_management(featureTable, temp_featureTable) arcpy.MakeFeatureLayer_management(baseFeature, temp_baseFeature) arcpy.MakeFeatureLayer_management(featureClass, temp_featureClass) # Get OID field name f_list = arcpy.ListFields(temp_featureClass) for f in f_list: if f.type == "OID": f_oid = f.name # Set Dictionary feat_dict = {} #set cursor rows = arcpy.SearchCursor(temp_featureClass) # loop for row in rows: feat_dict[row.getValue(f_oid)] = row.getValue("Local") for id in feat_dict: arcpy.MakeFeatureLayer_management(temp_featureClass, temp_layer, "%s = %s" % (f_oid, id)) arcpy.Clip_management(temp_baseFeature, "#", "catch%s.tif" % (feat_dict[id]), temp_layer, "0", "ClippingGeometry")
