Unspecified error when running the Buffer tool.
1045
5
08-14-2012 07:41 AM
GeorgeFaraj
I'm getting the following exception thrown when trying to run a Geoprocessing tool:
"Error HRESULT E_FAIL has been returned from a call to a COM component."    at ESRI.ArcGIS.Geoprocessing.GeoProcessorClass.Execute(String Name, IVariantArray ipValues, ITrackCancel pTrackCancel)    at ESRI.ArcGIS.Geoprocessor.Geoprocessor.ExecuteInner(IGPProcess process, ITrackCancel trackCancel, IGeoProcessor igp, IVariantArray iva)    at ESRI.ArcGIS.Geoprocessor.Geoprocessor.Execute(IGPProcess process, ITrackCancel trackCancel)    at GisViewer.GeoprocessingDialog.<RunSelectedTool>b__0() in C:\TASource\Source\MRA\PACS.NET-1.0\GisViewer\Dialogs\GeoprocessingDialog.cs:line 154
The code I'm using is:
  private IFeatureLayer GetSelectedLayers()   {    foreach (String item in featureList.CheckedItems)    {     for (int i = 0; i < synchronizer.MapControl.LayerCount; ++i)     {      var layer = synchronizer.MapControl.get_Layer(i);      if (layer.Name == item)      {       return layer as IFeatureLayer;      }     }    }     return null;   }    private IGPProcess GetSelectedTool()   {    var selectedTool = (GeoprocessorCommand.Command)toolCombo.SelectedItem;     if (selectedTool == GeoprocessorCommand.Command.Buffer)    {     var tool = new ESRI.ArcGIS.AnalysisTools.Buffer();     tool.in_features = GetSelectedLayers();     tool.out_feature_class = outputText.Text;     return tool;    }    else if (selectedTool == GeoprocessorCommand.Command.Clip)    {     var tool = new ESRI.ArcGIS.AnalysisTools.Clip();     return tool;    }    else if (selectedTool == GeoprocessorCommand.Command.Dissolve)    {     //var tool = new ESRI.ArcGIS.AnalysisTools.     //return tool;    }    else if (selectedTool == GeoprocessorCommand.Command.Intersect)    {     var tool = new ESRI.ArcGIS.AnalysisTools.Intersect();     return tool;    }    else if (selectedTool == GeoprocessorCommand.Command.Merge)    {     //var tool = new ESRI.ArcGIS.AnalysisTools     //return tool;    }    else if (selectedTool == GeoprocessorCommand.Command.Union)    {     var tool = new ESRI.ArcGIS.AnalysisTools.Union();     return tool;    }    return null;   }    private void RunSelectedTool()   {    new Thread(new ThreadStart(     delegate()     {      var processor = new Geoprocessor();      var tool = GetSelectedTool();       if (tool != null)      {       try       {        var results = (IGeoProcessorResult)processor.Execute(tool, null);        if (results.Status == ESRI.ArcGIS.esriSystem.esriJobStatus.esriJobSucceeded)        {         for (int i = 0; i < results.OutputCount; ++i)         {          var outputVal = results.GetOutput(i);          if (outputVal is DEFeatureClass)          {          }         }        }       }       catch (Exception)       {        MessageBox.Show("There was an error while running the geoprocessor", "Error", MessageBoxButtons.OK, MessageBoxIcon.Error);       }      }     }    )).Start();   }
I'm only testing the Buffer tool currently. I've checked, and the tool has both the in_features and out_feature_class assigned correctly before running the process. Any clues?
George Faraj
KenBuja
MVP Esteemed Contributor
One of the required properties you have to set for the Buffer tool is the buffer_distance_or_field, either a value or a numeric field. I don't see that property being assigned in your code. Also, when getting an error with one of the geoprocessing tools, the first thing I do is check the results window in ArcMap. It usually tells me why the tool has failed.
KenBuja
GeorgeFaraj
I tried specifying it using the following:
tool.buffer_distance_or_field = "500 METERS";
and
tool.buffer_distance_or_field = 150;
I'm still getting the same exception being thrown. Since I'm using the ArcGIS Runtime Engine, I can't see the results in the ArcMap application.
Any other ideas? Thanks for the help!
KenBuja
You should add some code to see what the messages in your results variable contain. Here's how I have it in one of my applications.
Dim Result As ESRI.ArcGIS.Geoprocessing.IGeoProcessorResult2
Dim ErrorMessage As String
Result = CType(GP.Execute(Process, Nothing), ESRI.ArcGIS.Geoprocessing.IGeoProcessorResult2)
If Result.Status <> ESRI.ArcGIS.esriSystem.esriJobStatus.esriJobSucceeded Then
    If Result.MessageCount > 0 Then
        For Count As Integer = 0 To Result.MessageCount - 1
            ErrorMessage += Result.GetMessage(Count)
        System.Windows.Forms.MessageBox.Show(ErrorMessage, "Geoprocessor failed")
    End If
End If
GeorgeFaraj
Apparently, it's a problem if the output file already exists. It works if I specify a file name that doesn't exist. Thanks for all the help!
KenBuja
If you don't need to worry about overwriting a file, you can set the IGeoprocessor::OverwriteOutput property to true.
