Using Python for Calculate Field
1281
08-07-2012 12:03 PM
KristenE
I am new to Python and was hoping someone could help me with this code. I just want to do a simple calculate field (as part of a larger script) and calculate one field to a few characters of text. All the examples I found online were much more complicated than what I needed help with. The following code results this error message:
ExecuteError: ERROR 999999: Error executing function.
Expected end of statement
Failed to execute (CalculateField).
I get the error message for the first Calculate Field.
Here is the code:
[INDENT]
import arcpy
from arcpy import env
# Define variables
env.workspace = r"Z:\package\CPP_scratch.gdb"
# This file name will change each month
eoptreps_v2 = r"Z:\package\Polygon_package.gdb\eoptreps_20120806"
print "Calculating project field - 1307"
arcpy.CalculateField_management(eoptreps_v2, "Project", "1307 - PNDI CPP")
print "Calculating project field - 1350"
if arcpy.Exists("eoptreps_lyr"):
    arcpy.Delete_management("eoptreps_lyr")
arcpy.MakeFeatureLayer_management(eoptreps_v2, "eoptreps_lyr")
if arcpy.Exists("StateForest_lyr"):
    arcpy.Delete_management("StateForest_lyr")
arcpy.MakeFeatureLayer_management(r"Z:\StateLayers.gdb\Boundaries_Natural\PA_StateForest", "StateForest_lyr")
arcpy.SelectLayerByLocation_management("eoptreps_lyr", "INTERSECT", "StateForest_lyr")
arcpy.CalculateField_management("eoptreps_lyr", "Project", "1350 - DCNR")
[/INDENT]
Things I have tried:
  • Changing "1307 - PNDI CPP" (the expression) to '[Project] = "1307 - PNDI CPP"' This results in the script running as if it works, but then when I check the field it is still NULL.
  • Changing the expression to "PGLMT PNDI" in case the dash was causing a problem. Same error message here.
MathewCoyle
Honored Contributor
Please read this.
http://forums.arcgis.com/threads/48475-Please-read-How-to-post-Python-code
As to your problem. What are your field names and types?
curtvprice
You need string delimeters inside the expression, which is itself a string. In Python this is easily done by escaping the double quote, or using the other kind of python string delimeter outside:
arcpy.CalculateField_management(eoptreps_v2, "Project", "\"1307 - PNDI CPP\"")
arcpy.CalculateField_management(eoptreps_v2, "Project", '"1307 - PNDI CPP"')
Double-quotes are used here because although we are using python, the default syntax expression for the Calculate Field tool is VBScript, which delimits string literals with double quotes.
KimOllivier
Honored Contributor
If you are in a Python script already I recommend that you do not use CalculateField, use a cursor.
CalculateField is useful in ModelBuilder and interactive table manipulation but not in a script.
It is no faster than a cursor (especially at 10.1 da module)  because CalculateField simply wraps a cursor around the expression.
With a cursor you can:
  • Trap errors with a try/except block
  • Test for unexpected data and handle it properly (eg null values)
  • Debug easily by adding print statements
  • Write the expressions without complicated syntax (no !wrappers! or [access_speclal] brackets)
  • Do multiple field calculations at once
  • Use a dictionary to update values to avoid a join
