Solved! Go to Solution.
[ { "op": "core/column-move", "description": "Move column Commonly Used Street*Suffix or Abbreviation to position 0", "columnName": "Commonly Used Street*Suffix or Abbreviation", "index": 0 }, { "op": "core/column-removal", "description": "Remove column Primary Street Suffix", "columnName": "Primary Street Suffix" }, { "op": "core/row-removal", "description": "Remove rows", "engineConfig": { "facets": [ { "invert": false, "expression": "isBlank(value)", "selectError": false, "omitError": false, "selectBlank": false, "name": "Commonly Used Street*Suffix or Abbreviation", "omitBlank": false, "columnName": "Commonly Used Street*Suffix or Abbreviation", "type": "list", "selection": [ { "v": { "v": true, "l": "true" } } ] } ], "mode": "row-based" } }, { "op": "core/text-transform", "description": "Text transform on cells in column Commonly Used Street*Suffix or Abbreviation using expression value.trim()", "engineConfig": { "facets": [ { "invert": false, "expression": "isBlank(value)", "selectError": false, "omitError": false, "selectBlank": false, "name": "Commonly Used Street*Suffix or Abbreviation", "omitBlank": false, "columnName": "Commonly Used Street*Suffix or Abbreviation", "type": "list", "selection": [ { "v": { "v": false, "l": "false" } } ] } ], "mode": "row-based" }, "columnName": "Commonly Used Street*Suffix or Abbreviation", "expression": "value.trim()", "onError": "keep-original", "repeat": false, "repeatCount": 10 }, { "op": "core/text-transform", "description": "Text transform on cells in column Commonly Used Street*Suffix or Abbreviation using expression value.trim()", "engineConfig": { "facets": [], "mode": "row-based" }, "columnName": "Commonly Used Street*Suffix or Abbreviation", "expression": "value.trim()", "onError": "keep-original", "repeat": false, "repeatCount": 10 }, { "op": "core/text-transform", "description": "Text transform on cells in column Commonly Used Street*Suffix or Abbreviation using expression value.replace(/\\s+/,' ')", "engineConfig": { "facets": [], "mode": "row-based" }, "columnName": "Commonly Used Street*Suffix or Abbreviation", "expression": "value.replace(/\\s+/,' ')", "onError": "keep-original", "repeat": false, "repeatCount": 10 }, { "op": "core/text-transform", "description": "Text transform on cells in column Commonly Used Street*Suffix or Abbreviation using expression grel:value.replace(\"\\s\",value)", "engineConfig": { "facets": [], "mode": "row-based" }, "columnName": "Commonly Used Street*Suffix or Abbreviation", "expression": "grel:value.replace(\"\\s\",value)", "onError": "keep-original", "repeat": false, "repeatCount": 10 }, { "op": "core/text-transform", "description": "Text transform on cells in column Commonly Used Street*Suffix or Abbreviation using expression grel:value.replace(\" \",value)", "engineConfig": { "facets": [], "mode": "row-based" }, "columnName": "Commonly Used Street*Suffix or Abbreviation", "expression": "grel:value.replace(\" \",value)", "onError": "keep-original", "repeat": false, "repeatCount": 10 } ]
Here was my process if interested:
- Visited the official USPS abbreviation list
- Copied everything in the Street Suffixes section
- Pasted it into MS Excel (to preserve tables)
