Hi,I'm trying to copy all information from one string field to a new one in the same feature class. I am using this code:
#Feature class:
Tab = r'\\Tako\gis\03_basisdaten\pronatura\ch\gisdata\pronatura_1.gdb\Schutzgebiete\parz_pn'
#Field:
orgField = "Bemerkungen"
#Length of Field:
Length = 1000
#Adding the new Field:
provField = orgField + "_prov"
AddField_management(Tab,provField,"TEXT", "", "", Length)
#Copy the information from the original field to the new one:
Expression = 'str(!%s!)' %(orgField)
CalculateField_management(Tab, provField, Expression, 'PYTHON')
The tool stops at feature 52 of 2500 and gives this Error:Runtime error <class 'arcgisscripting.ExecuteError'>: ERROR 000539: Error running expression: str("1x jährlich im Herbst zu mühen. Er verwendet Flurname "Hiwes", vormals Parz. 200310 ") <type 'exceptions.SyntaxError'>: invalid syntax (<string>, line 1) Failed to execute (CalculateField).
I assume there is some problem with the " in the string to copy. How can I tell Python to treat the string as one and ignore all special characters?
