env.workspace treated as a string?
1947
07-30-2012 09:08 AM
ZulyG
[/HR]
Every time I try to set the workspace on my script. I get the following error:
'exceptions.AttributeError'>: 'str' object has no attribute 'workspace'
I have tried  running it on the IDE and I get the same error :
import arcpy
from arcpy import env
arcpy.env.workspace =  "C:/Documents and Settings"
I had previously used it but for some reason now it seems like it is treating the env as a string.  Any ideas as to how to fix this?
JasonScheirer
Esri Alum
Did you accidentally do something like
arcpy.env = 'string'
earlier in your script?
markdenil
can you read the workspace setting?
print arcpy.env.workspace
can you read or write any other arcpy.env property?
Try reading them with
import arcpy
environments = arcpy.ListEnvironments()
for environment in environments:
    envSetting = eval("arcpy.env." + environment)
    print "%-30s: %s" % (environment, envSetting)
print "\nDONE"
Luke_Pinner
MVP Regular Contributor
You're also importing env separately. I don't think this will make any difference, but it is uneccessary.  Just use:
import arcpy
markdenil
That is right.
Since you imported env separetly, use
env.workspace = r"C:\spam\a\lot"
you can then read it using
or
print env.workspace
but setting it with
arcpy.env.workspace = r"C:\spam\a\lot
will give an error
