showing ProgessDialog when loading a MapView
1710
07-29-2012 05:14 AM
Chrisvan_Aart
I am looking for a way to show the progress dialog when loading a MapView.
MapView map = new MapView(this, url, "", "");
GuyNahmani
I did something like that i the past.
// Declare your loading map with status recognition in getUnits() function.
viewUnits = new Runnable(){
            @Override
            public void run() {
             getUnits();
        //It'll stope the progress only after finish with getUnits(); there you'll do the map's status check.
        Thread thread =  new Thread(null, viewUnits, "MagentoBackground");
        thread.start();
        m_ProgressDialog = ProgressDialog.show(UnitsModelListViewActivity.this,
              "Please wait...", "Retrieving data/Loading ...", true);
Hope it'll help you...
Enjoy!
NicoTek
@guy_nach
Could you explain a bit more to me what your code does? I'm also interested in implementing something similar.
When I add dynamic layers to my mapview the take a bit to show because my server is not that fast, so there I would like to show a progress bar.
I don't fully understand how to implement your solution, but would like to use it.
Thanks!
@2cm
what did you end up doing?
SimonKlein
If I understand you correctly you can just create and show a progressdialog when you add the layer and disable it in the onstatuschangedlistener of your mapview when "layerloaded" is called with the id/name/etc. of your added layer.
