Web Adaptor Error - 404 Not Found
8486
07-16-2012 11:34 PM
Yi_LikTsang
We have just installed ArcGIS Server 10.1 on
* Windows Server 2003 R2 Standard x64 Edition
* IIS 6.0
Both the ArcGIS Server (http://machine_fqdn:6080/arcgis/) and the Web Adulator (http://machine_fqdn/arcgis/webadaptor) have been installed and is running.   We are also to use the web adapter administration page to register to the GIS Server, and we get that green successful box
Status: The following GIS servers are registered to your Web Adaptor
    *** machine_fqdn ***
Last updated on 7/17/2012 3:23:56 PM
You can now use the URL (http://machine_fqdn/arcgis/rest/services) for accessing services in the Services Directory.
However, when we click on the link, we simply get a "The page cannot be found" 404 error.
If I just use http://machine_fqdn/arcgis, this will get redirected to http://machine_fqdn/arcgis/rest/services, and then 404 again, so form that, I think the webadaptor is kind of working, but failing half way through.
And unfortunately, there is not a single error message from the tomcat (C:\Program Files\ArcGIS\Server\framework\runtime\tomcat\logs) or arcgis server (C:\arcgisserver\logs\***\server) logs
Anybody having the same issue??  And know how to fix it??
Yi-Lik
GerardoArmendariz
I was having a similar issue.  For some reason, when I switched the machine name with the machine's ip address it worked.  Try using http://[IPADDRESS]/arcgis.
