html popup-customisation with frame
697
07-06-2012 12:25 AM
olaflinke
with a collegue we had a look on the html pop-up subject.
I see the pop-up option as a suitable replacement for an direct link between GIS and database, which to realize seems rather
demanding.
But I'd like to present the information in a popoup-window of the same size for all objects, independant from
the amount of contained information in the table. At present the pop-up window differs in size each time I click an object
in the map
Found a hint to the 'iframe'-tag. During a first attempt to apply this it did not work. I noticed that the .xsl structure in
the example code from the web looks different to the code in the popupcss.xsl from 9.3. So I'm not sure about the right place
for that iframe-tag and if it works at all.
Can anybody help in that situation or knows a better, easy accessible solution ?
