private void showText(double x, double y) { IGraphicsContainer graphicsContainer = axMapControl1.Map as IGraphicsContainer; IElement element = new TextElementClass(); ITextElement textElement = element as ITextElement; //Create a point as the shape of the element. IPoint point = new PointClass(); point.X = x; point.Y = y; element.Geometry = point; textElement.Text = "Hello World"; graphicsContainer.AddElement(element, 0); //Flag the new text to invalidate. IActiveView activeView = axMapControl1.Map as IActiveView; activeView.PartialRefresh(esriViewDrawPhase.esriViewGraphics, null, null); }
private void createPictureElement(double x, double y) { ESRI.ArcGIS.Carto.IPictureElement pPictureElement; pPictureElement = new ESRI.ArcGIS.Carto.JpgPictureElementClass(); pPictureElement.ImportPictureFromFile(@"D:\__VS\�?конки\�?н�? заболевания л�?дей.JPG"); //((IElement)pPictureElement).. ESRI.ArcGIS.Geometry.IEnvelope pEnv = new ESRI.ArcGIS.Geometry.EnvelopeClass(); pEnv.PutCoords(x, y, x+1000,y+1000); ESRI.ArcGIS.Carto.IElement pElement; pElement = pPictureElement as ESRI.ArcGIS.Carto.IElement; pElement.Geometry = pEnv; ESRI.ArcGIS.Carto.IGraphicsContainer pGraphicContainer; pGraphicContainer = axMapControl1.Map as IGraphicsContainer; pGraphicContainer.AddElement(pElement, 0); ESRI.ArcGIS.Carto.IActiveView pActiveView; pActiveView = pGraphicContainer as ESRI.ArcGIS.Carto.IActiveView; pActiveView.PartialRefresh(ESRI.ArcGIS.Carto.esriViewDrawPhase.esriViewGraphics, pElement, pEnv); }
((IOlePictureElement)pPictureElement).ImportPicture(IPictureDispHost.GetIPictureDispFromPicture(pictureBox.Image) as stdole.IPictureDisp);
internal sealed class IPictureDispHost : AxHost { private IPictureDispHost() : base("{63109182-966B-4e3c-A8B2-8BC4A88D221C}") { } /// <summary> /// Convert the image to an ipicturedisp. /// </summary> /// <param name="image">The image instance</param> /// <returns>The picture dispatch object.</returns> public new static object GetIPictureDispFromPicture(Image image) { return AxHost.GetIPictureDispFromPicture(image); } /// <summary> /// Convert the dispatch interface into an image object. /// </summary> /// <param name="picture">The picture interface</param> /// <returns>An image instance.</returns> public new static Image GetPictureFromIPicture(object picture) { return AxHost.GetPictureFromIPicture(picture); } }
