Programmatically remove a command from a context menu?
1069
06-28-2012 03:21 PM
SuiHuang
Hi Everybody:
    I know that I can use ICommandBar.Add(contextMenuUID, ref position) to add a command to a context menu of ArcMap. However, there is no "remove" method in ICommandBar interface. Is there any way to programmatically remove an added command in some state of the ArcObjects extension?
    Thank you!
NeilClemmons
Honored Contributor
Use ICommandBar.Find to get a reference to the command item then call ICommandItem.Delete.
NeilClemmons
Honored Contributor
SuiHuang
Thank you Neil!
