Quick export CSV w/ headers via python
5493
06-22-2012 11:17 AM
gregmohler
I'm looking to export a large feature class (55k+ records) to csv with headers.  Can anyone help with how to set the parameters in python?
Using Arcmap and looking in the results windows after setting parameters gives:
CSV,S:\\Folder,"RUNTIME_MACROS,""APPEND,No,FIELD_NAMES,yes,SEPARATOR,"""","""",EXTENSION,csv"",META_MACROS,""DestAPPEND,No,DestFIELD_NAMES,yes,DestSEPARATOR,"""","""",DestEXTENSION,csv"",METAFILE,CSV,COORDSYS,,__FME_DATASET_IS_SOURCE__,false"
This gives me what i need, but I would rather not open Arcmap.  I've tried setting these items above a few ways to no avail.
I just need the input, output, and headers to be written.  From python with just input and output gives me a csv with no headers.
Python 2.6 with arc10.0.
Thanks for any help.
DarrenWiens2
I don't know about Quick Export, but this exports a feature class to csv, with headers.
import arcpy, csv fc = "H:/GIS_Data/TEMP.gdb/points" #input feature class rows = arcpy.SearchCursor(fc) csvFile = csv.writer(open("H:/GIS_Data/csvfile.csv", 'wb')) #output csv fieldnames = [f.name for f in arcpy.ListFields(fc)]  allRows = [] for row in rows:     rowlist = []     for field in fieldnames:         rowlist.append(row.getValue(field))     allRows.append(rowlist)      csvFile.writerow(fieldnames) for row in allRows:     csvFile.writerow(row)
*mostly stolen from here
JasonScheirer
Esri Alum
Right click on the result in the results window and copy as Python snippet.
gregmohler
That would be what i posted above.
Is there a special way to copy as python snippet?
I tried this
arcpy.QuickExport_interop('S:\Tech\Greg_Mohler\pythonwork\gm_sw_py.gdb\SW_LINE CSV','S:\Tech\Greg_Mohler\pythonwork',"RUNTIME_MACROS,""APPEND,No,FIELD_NAMES,yes,SEPARATOR,"""","""",EXTENSION,csv"",META_MACROS,""DestAPPEND,No,DestFIELD_NAMES,yes,DestSEPARATOR,"""","""",DestEXTENSION,csv"",METAFILE,CSV,COORDSYS,,__FME_DATASET_IS_SOURCE__,false")
and I got this:
TypeError: QuickExport() takes at most 2 arguments (3 given)
DarrenWiens2
gregmohler
import arcpy, csv
allRows = []
for row in rows:
    rowlist = []
for row in allRows:
This works for the most part.  Someone used degrees symbols and other odd characters and i'm having encoding/decoding issues.
