Merging with Python
3324
6
06-22-2012 10:45 AM
JamesMitchell
I hope somebody can please help me with a script i am developing below. It buffers an input and then select the features within the buffer but then doesnt do the merge. I assume it is to do with the List i am using as the merge input. When i run this through the python window in ArcMap it seems to work.
Any help will be greatly appreciated as i am quite stuck at the moment and have tried everything i can think of.
Thank you
James
import arcpy, os, string, arcgisscripting
#Read input parameters from script tool
LayersList = string.split(arcpy.GetParameterAsText(0),";")
Site_Boundary = arcpy.GetParameterAsText(1)
BufferDistance = arcpy.GetParameterAsText(2)
OutputFolderLocation = arcpy.GetParameterAsText(3)
# Process: Buffer
arcpy.Buffer_analysis(Site_Boundary, OutputFolderLocation + "\\" + BufferDistance + "_Buffer.shp", BufferDistance, "FULL", "ROUND", "NONE", "")
# Process: Loop Layers
for Layer in LayersList:
# Get filename of layer
LayerName = os.path.basename(Layer).strip("'") + "_FL"
# Process: Make Feature Layer (In, Out)
arcpy.MakeFeatureLayer_management(Layer.strip("'"), LayerName)
# Process: Select Layer By Location
arcpy.SelectLayerByLocation_management(LayerName, "INTERSECT", OutputFolderLocation + "\\" + BufferDistance + "_Buffer.shp", "0 Meters", "NEW_SELECTION")
arcpy.CopyFeatures_management(LayerName, OutputFolderLocation + "\\" + LayerName)
#Create List and Add Layers to the List
L = list ()
L.append(LayerName)
# Process: Merge Selected Features
arcpy.Merge_management(L, OutputFolderLocation + "\\All_Sites.shp")
DarrenWiens2
Try:
L = []
JasonScheirer
Esri Alum
arcpy.Merge_management(";".join(L), OutputFolderLocation + "\\All_Sites.shp")
DarrenWiens2
From the help, it looks like the input list should be comma delimited for merge, not semi-colons. Am I wrong?
edit: I just tried my way and it works.
 L = []
 L.append(LayerName)
JamesMitchell
Thank you for the replies. I have tried both ways but the merge only contains one layer. Please can you shed any further light on this?
Thank you very much.
JamesMitchell
Hello again,
I have managed to get this to work. I just needed to move the L = list() before the for loop. I assume it kept recreating the list and therefore ended up only containing the last layer from the layerslist.
NolanGeise
Just used this and it seems to work great, thanks
