VBScript label expression for dates.
5734
06-12-2012 11:04 AM
PaulHuffman
I thought I could reformat a date variable to drop the year for a map label but all I can get from the label expression advanced box is "The expression contains an error. Modify the expression and try again."  Tried
FormatDateTime([StartDate], 1)
and
Function ShortDate ( [StartDate] )
  ShortDate = FormatDateTime([StartDate],1)
End Function
where StartDate is a date item in my table formated mm/dd/yyyy For the second FormatDateTime argument, I've tired 1 and 0.
KenBuja
MVP Esteemed Contributor
I'm able to get the formatted date for my date field [SUR_DATE] in the label using the line
FormatDateTime([SUR_DATE])
To drop the year, I had use the syntax
Month( [SUR_DATE] ) & "/" & Day([SUR_DATE])
KenBuja
PaulHuffman
Thanks, Ken, that's working for me.
But the other thing I was trying to do to make the same label was to create a new item and use the field calculator and python to calculate the shorter date string. I thought I knew more about python but I couldn't get the syntax right.  It seems like you'd use strftime, but maybe it doesn't work because the source item is already a date, not a string.
