Can you query a variable in Select_analyis?
1114
06-06-2012 02:30 PM
LeeEllenburg
I an having troubles querying a variable using the arcpy.Select_analysis() tool.
For example:
import arcpy from arcpy import env   env.workspace = "D:\\Lee\\IrrigationProject"  In = "boombuffer.shp" Out = "D:\\Lee\\IrrigationProject\\IrrigationModel\\BoomBuffers\\Boom" Boom = 1  arcpy.Select_analysis(In, Out + str(Boom) + ".shp" , '"BoomNumber" = 'Boom'')
This is not valid syntax, however I can't seem to figure it out. I would like to include this in a loop that would create a new shapefile from each feature in the input shapefile.
Any help would be greatly appreciated.
MathewCoyle
Honored Contributor
That sounds like you are trying to do a Split
If you need more control than that, this should work. Assumes BoomNumber is a numeric value.
import arcpy from arcpy import env  env.workspace = "D:\\Lee\\IrrigationProject"  In = "boombuffer.shp" Out = "D:\\Lee\\IrrigationProject\\IrrigationModel\\BoomBuffers\\Boom"  boom_list = [] boom = None field_name = "BoomNumber" delim_field_name = arcpy.AddFieldDelimiters(env.workspace,field_name)  # Creates and runs cursor to add all unique values to a list s_curs = arcpy.SearchCursor(In) for s_row in s_curs:     add_val = s_row.getValue(field_name)     if add_val not in boom_list:         boom_list.append(add_val)  # Loops through list of unique boom values and export each one to a new shapefile for boom in boom_list:     arcpy.Select_analysis(In, Out + str(boom) + ".shp", "{0} = {1}".format(delim_field_name,boom)
MathewCoyle
Honored Contributor
Something like this should work.
variable = "Boom"
arcpy.Select_analysis(In, Out + str(Boom) + ".shp", "{0} = '{1}'".format(delim_field_name,variable)
Or maybe I didn't understand what you are trying to do. Is Boom your attribute or your variable you want to pass?
LeeEllenburg
Yes, Boom is the variable I would like to pass. It would increase with each iteration ideally, effectively exporting each feature as it's own shapefile.
MathewCoyle
Honored Contributor
LeeEllenburg
Ahhh, yes. Split will work just fine! Thanks.
