UpdateCursor Variable Syntax
1075
06-04-2012 11:31 AM
AlanToms
Hello All,
I am working on a script with an updatecursor and running into a syntax problem???I think.  My variables are hardcoded at this time, till I get it working.  The feature class and field to update are variables.  I think line row.inputField = 6 is where I believe I have the problem; line row.LinkID = 5 does work as LinkID is a field name.  It is looking for a field by the name of inputField instead of a variable.  I'm sure it is something simple.  Anyone have a suggestion?
Thank you for the help.
Alan
import arcgisscripting  # Create the Geoprocessor object gp = arcgisscripting.create(9.3)  # Input Variables inputFC = r"C:\GIS_Work\Temp.gdb\Subs" inputField = "LinkID"  cur = gp.UpdateCursor(inputFC) row = cur.Next() while row:     #row.LinkID = 5     row.inputField = 6         cur.UpdateRow(row)     row = cur.Next()     print "Value Added"          print "UpdateCursor Works"
MathewCoyle
Honored Contributor
What you want is this. Not sure of the exact syntax for 9.3 might be row.SetValue(...)
row.setValue(inputField,6)
MathewCoyle
Honored Contributor
AlanToms
Wow total brain lock on my part.  Thanks for the help.
Alan
