Import module - undefined global variable
1562
06-04-2012 08:00 AM
DonBarker
I thought I understood and fixed this problem:  A variable defined in a module remains undefined after I import the module.  Here is the simplified version.
The main script and the module are in the same folder/dir.
This is my module:  mysettings.py
def main():
    myvar = "This is imported."
if __name__ == '__main__':
    main()
This is my script:  irp.py:
import mysettings
def main():
    print myvar
    main()
Interpreter error:
NameError: global name 'myvar' is not defined
Can you tell me why?
MathewCoyle
Honored Contributor
You need to do something like this in your irp.py
mysettings.main()
When you import a module it isn't executed as the __main__ so it needs to be called by function if you have it setup that way.
DonBarker
Matthew,
Thanks for taking time to reply.
I'm a Python novice so don't understand how/where to use this in my script.  Can you explain?
MathewCoyle
Honored Contributor
Your mysettings.py should be something along these lines, depending on what it does.
def main():
    return myvar
    main()
Your irp.py should be something like this.
import mysettings
def main():
    print mysettings.main()
    main()
DonBarker
Got it now.  Thanks again for taking time to reply and explain.
