Increment Numbers with Sort Field
1376
06-04-2012 04:58 AM
AlanToms
Hello All,
I would like to create code to calculate a field with increment numbers, similar to this code, but with an option of a sort order.  I�??m thinking I could use an UpdateCursor with a sort and loop through the records, but I assume the performance would suffer vs a strait up field calculation.  Another option I was considering was a SearchCursor then calling the Calculate Field geoprocess for each record.  I don't think this would improve performance though.
Are there any suggestions or thoughts?
Thank you
Alan
MathewCoyle
Honored Contributor
Cursors are much faster than field calculations, so performance would improve using an UpdateCursor.
AlanToms
I have a feature class with 266,927 records which I used to test the field calculation and the UpdateCursor.  The field calculation was substantially faster than the UpdateCursor.  The field calculation completed in 37 seconds.  The UpdateCursor took 8 minutes and 50 seconds.  My code is a bit more complicated because it includes a sort order, but I wouldn�??t expect to be that much of a performance hit.  If UpdateCursor is supposed to be quicker any idea where I may have slowed the process down?
Field Calculation
rec=0
def autoIncrement():
 global rec
 pStart = 1 #adjust start value, if req'd
 pInterval = 1 #adjust interval value, if req'd
 if (rec == 0):
  rec = pStart
 else:
  rec = rec + pInterval
 return rec
My UpdateCursor code
import arcgisscripting
# Create the Geoprocessor object
gp = arcgisscripting.create(9.3)
# Input Variables
inputFC = gp.GetParameterAsText(0) #Input Feature Class
inputField = gp.GetParameterAsText(1) #Field to calculate
inputStart = gp.GetParameterAsText(2) #Starting value.  Default value of 1 in ArcToolbox
inputIncrement = gp.GetParameterAsText(3) #Incement value. Default value of 1 in ArcToolbox
inputSortField = gp.GetParameterAsText(4) #Field to sort by
inputSortOrder = gp.getparameterastext(5) #Sort order. Value List (Ascending, Descending) with a default value of Ascending in ArcToolbox
def sortVariable(xSortField,xSortOrder):
    if xSortOrder == "Descending":
        return xSortField + " D"
    else:
        return xSortField + " A"
# UpdateCursor
def incrementNumbers(vFC,vField,vStart,vIncrement,vFieldList,vSort):
    try:
        value = int(vStart)
        cur = gp.UpdateCursor(vFC,"","",vFieldList,vSort)
        row = cur.Next()
        while row:
                row.setValue(vField,value)
                cur.UpdateRow(row)
                row = cur.Next()
                value = value + int(vIncrement)
    except:
        # Warning messages
        print gp.AddWarning(gp.GetMessages(1))
        # Error messages
        print gp.AddError(gp.GetMessages(2))
    print gp.AddMessage("Complete")
# Variable of fields to use in the UpdateCursor
qFieldList = inputField + "," + inputSortField
# Variable for sort to use in the UpdateCursor
qSort = sortVariable(inputSortField,inputSortOrder)
incrementNumbers(inputFC,inputField,inputStart,inputIncrement,qFieldList,qSort)
MathewCoyle
Honored Contributor
If the field isn't indexed and has a lot of unique variables the sort can take a while. I wouldn't think it would be in the order of 8 minutes though. The 9.3 cursors were not quite as fast if I recall. If you are reading the feature class in the update cursor instead of a layer how you are with the field calculator that can also have an impact.
AlanToms
I figured the indexed may make a difference so I used the ObjectID field when I ran it.  I'll attempt to rewrite it using arcpy and see how it turns out.  Thanks for the feedback on this.
Alan
