Spatial join between one target feature and several join features ?
1735
05-31-2012 02:00 AM
HeidiSevestre
Dear all with Python experience,
In advance, please excuse the little experience I have dealing with Python, as I am trying to write my very first script!
My situation is that I would like to perform spatial join between one single "target feature" and several "join features". The aim is to create as many output files as I have join features.
In addition (but I have absolutely no idea how) I would like each output file to keep the file name from the join feature file.
So far, my script looks like this:
import arcpy
import os
# Create the geoprocessor object
try:
     # 9.2 and beyond
     import arcgisscripting
     gp = arcgisscripting.create()
     print "\nImporting geoprocessor for 9.2 and beyond..."
except:
     # 9.1 and before
     import win32com.client
     gp = win32com.client.Dispatch("esriGeoprocessing.GpDispatch.1")
     print "\nImporting geoprocessor for 9.1 and before..."
targetFeatures = "G:/PhD/ERA 40/WorkPython/target/"
joinFeatures = "G:/PhD/ERA 40/WorkPython/join/"
outfc = "G:/PhD/ERA 40/WorkPython/Output"
# Read all the shapefiles in folder 'joinFeatures'
gp.SpatialJoin(targetFeatures, joinFeatures, outfc, "JOIN_ONE_TO_ONE", "KEEP_ALL")
print "\nDone."
Without surprises this script doesn't perform well, and I am not able to get anything out of it.
My target feature file is "Alaska_20111229_geog_glaciers.shp"
My join feature files are called "09011981small.shp", the first 8 digits changing for every single file.
Any help/improvement/advice would be very much appreciated. Thank you!
Kind regards,
Heidi
MarcinGasior
This code may be a good start for you (I assume you're using ArcGIS 10):
try:     import arcpy, os     arcpy.env.workspace = "G:/PhD/ERA 40/WorkPython/join"     targetFeatures = "G:/PhD/ERA 40/WorkPython/target/Alaska_20111229_geog_glaciers.shp"     outDirectory = "G:/PhD/ERA 40/WorkPython/Output"      #take all shapefiles from .../join folder which name contains "small" at the end     fcList = arcpy.ListFeatureClasses("*small")      #for each "small" feature class perform spatial join     for featureClass in fcList:         outFeatureClass = os.path.join(outDirectory, featureClass)         arcpy.SpatialJoin_analysis(targetFeatures, featureClass, outFeatureClass)  except:     print arcpy.GetMessages()
To preserve indentation select your code and click Wrap
 tags around selected text
HeidiSevestre
(and sorry about the indentations that have mysteriously disappeared from my script)
MarcinGasior
HeidiSevestre
Thank you for this quick and instructive reply.
I have just tried your script, and I get:
Parsing error <type 'exceptions.SyntaxError'>: invalid syntax (line 12)
which is the "except:"
Should there be an indentation before except?
Thanks again for your help.
Heidi
HeidiSevestre
Thank you very very much! The script works perfectly fine, and is very simple and neat.
Greetings from Norway
Heidi 🙂
