Error from AccessWorkspaceFactory.Create
2446
8
05-30-2012 06:26 AM
JohnFritzen
For the following code....
 Dim pWorkspaceName As ESRI.ArcGIS.Geodatabase.IWorkspaceName
 Dim pWorkspaceFactory As ESRI.ArcGIS.Geodatabase.IWorkspaceFactory
 'Set up new database
 pWorkspaceFactory = New ESRI.ArcGIS.DataSourcesGDB.AccessWorkspaceFactory
 pWorkspaceName = pWorkspaceFactory.Create("C:\Temp", "foo.mdb", Nothing, 0)
I get the error...
System.Runtime.InteropServices.COMException was caught
  ErrorCode=-2147220973
  Message=Exception from HRESULT: 0x80040213
  Source=ESRI.ArcGIS.DataSourcesGDB
  StackTrace:
       at ESRI.ArcGIS.DataSourcesGDB.AccessWorkspaceFactoryClass.IWorkspaceFactory2_Create(String parentDirectory, String Name, IPropertySet ConnectionProperties, Int32 hWnd)
I am using vs2010 and ArcMap 10.
The code is in a windows form.  The form is called from a ICommand class.  My code was converted from VB6 and ESRI 9.x.
When I am debugging, this line and step into it
It goes to the Deactivate subroutine of the Form code.
Thanks for your help!
RichWawrzonek
This problem comes up frequently in this forum.
Workspaces are singleton objects and you should use the activator class to instantiate them. See documentation:
http://help.arcgis.com/en/sdk/10.0/arcobjects_net/conceptualhelp/index.html#//00010000043p000000
In your case the line:
should be replaced with:
pWorkspaceFactory = CType(Activator.CreateInstance(Type.GetTypeFromProgID("esriDataSourcesGDB.AccessWorkspaceFactory")), IWorkspaceFactory)
JohnFritzen
Hi Rich,
Thanks for your help.  The documentation on singleton objects was also very helpful.
Unfortunately the problem persists.
RichWawrzonek
You need to make sure the specified directory (C:\Temp in your case) already exists. The IWorkspaceFactory.Create() method will not create it for you.
JohnFritzen
Yes, that dir exists.
RichWawrzonek
Is this an ArcGIS COM extension or a standalone app?
JohnFritzen
It is a COM extension.  Runs in a windows form launched from an icommand class.
NeilClemmons
Honored Contributor
There are several things that could cause an issue here.
As already mentioned, use the Activator class to create an instance of the workspace factory.  Also mentioned, the directory C:\Temp must already exist.  Additionally, the database foo.mdb should not already exist.  I don't think the Create method will overwrite an existing database.  The final parameter to Create is a window handle.  Since you're calling this method from a Windows Form, you should be passing in the handle of that form (Form.Handle.ToInt32).  In cases where the code is not called from a form, use the application's handle (IApplication.hWnd).  You also need to have write permissions on the Temp directory.  I can't imagine why you wouldn't but if the code is still failing you might want to make sure.
JohnFritzen
Thanks for your help.  I did try a version of the code passing a window handle.  I also tried passing and empty property object instead of "Nothing".
