Why when I try to run any of the tools in the Zonal toolbox in the Python window or use any of those tools in a Python script do I get the following error? "Runtime error <type 'exceptions.AttributeError'>: 'module' object has no attribute 'TabulateArea_sa'" I am using ArcGIS 10.0 service pack 4.
So you get this error anytime you run any of the zonal tools? Do you have this same problem if you run any of the Zonal tools directly from the toolbox too? Hmm... You might have something wrong with your install of ArcGIS/Spatial Analyst... After exhausting other ideas, you can always try a reinstall.
