Related Records Query
3846
5
05-15-2012 06:52 AM
ChristopherEbright
I am having trouble implementing AGSRelationshipQuery, I get a successful response, but the data returned id not what I expect and I am not sure if I am setting up my query the correct way. What I am trying to do is query related records from a point feature class (through a map service) that has a relationship set up with a table.
Here is code: (the names of the server and services have been changed to protect the innocent, and unfortunately, this server is not public so i can't point anybody to it)
- (void)mapView:(AGSMapView *)mapView didClickCalloutAccessoryButtonForGraphic:(AGSGraphic *)graphic {
    self.queryTask = [AGSQueryTask queryTaskWithURL:[NSURL URLWithString:@"http://<myServer>/arcgis/rest/services/<myFolder>/<myService>/MapServer/0"]];
    self.queryTask.delegate = self;
    self.relQuery = [AGSRelationshipQuery relationshipQuery];
    self.relQuery.objectIds = [NSArray arrayWithObject:[graphic.attributes objectForKey:@"OBJECTID"]];
    self.relQuery.outFields = [NSArray arrayWithObject :@"*"];
    self.relQuery.relationshipId = 0;
    [self.queryTask executeWithRelationshipQuery:self.relQuery];
- (void) queryTask:(AGSQueryTask *)queryTask operation:(NSOperation*)op didExecuteWithRelatedFeatures:(NSDictionary *)relatedFeatures {
   NSLog(@"relatedFeatures: %@", relatedFeatures);
The response I get back from the NSLog on related Features is:
relatedFeatures: (
    "AGSFeatureSet: display name: (null)
\ngeometry type: esriGeometryPoint
\nnum features: 1
\nspatial reference: (null)"
I have confirmed the parameters in my query are valid using the rest/services web page, and there I get a json object that has the data I expect. But I am not sure what to make of the response I am getting through the iOS API.
I have also tested the a regular http request using the direct URL for the REST query, and I do get back the proper response,
    NSString *relatedQueryString = @"http://<myServer>/ArcGIS/rest/services/<myFolder>/<myService>/MapServer/0/queryRelatedRecords?objectIds=1&relationshipId=0&definitionExpression=&returnGeometry=false&maxAllowableOffset=&outSR=&outFields=*&f=pjson";
    NSError *theError = nil;
    NSMutableURLRequest *request = [NSMutableURLRequest requestWithURL:[NSURL URLWithString:relatedQueryString]];
    NSURLResponse *theResponse = [[NSURLResponse alloc] init];
    NSData *data = [NSURLConnection sendSynchronousRequest:request returningResponse:&theResponse error:&theError];
    NSString *string = [[NSString alloc] initWithData:data encoding:NSUTF8StringEncoding];
    NSDictionary *jsonDict = [string AGSJSONValue];
so I am figuring I am just not setting up the related request correctly.
Chris
DiveshGoyal
Are you sure that the graphic you're getting back in the didClickCalloutAccessoryButtonForGraphic: parameter has any related records?
For example, if you have multiple layers in your map, the graphic could belong to a completely different layer.
Just to rule out such problems, I would try running the query by hardcoding the objectid (instead of getting it from the graphic's attributes). If things still don't work, we can troubleshoot more.
ChristopherEbright
Good thought, but still did not work. I am logging the objectid and it is returning the correct one, and if i compare to a manual rest query, the related records are there.
NimeshJarecha
Chris,
Could you please print your result with this code and check? Also, in your query, please set self.relQuery.returnGeometry = TRUE if you want the geometry.
for(NSString *aKey in relatedFeatures)
 NSLog(@"Key: %@ Value: %@", aKey, [relatedFeatures objectForKey:aKey]);
 AGSFeatureSet *featureSet = [relatedFeatures objectForKey:aKey];
 for (int i=0; i< [featureSet.features count]; i++) {
  AGSGraphic *graphic = [featureSet.features objectAtIndex:i];
  NSLog(@"graphic: %@",graphic);
Regards,
Nimesh
ChristopherEbright
Here is what I got:
2012-05-18 11:08:33.738 WPC_Mobile[7173:707] Key: 6675 Value: AGSFeatureSet: display name: (null)
num features: 1
2012-05-18 11:08:33.741 WPC_Mobile[7173:707] graphic: geometry: (null), symbol: (null), attributes: {
    CompletionRecID = 10214;
}, visible: 1
This is what I was looking for. It looks like I failed to go into the FeatureSet.features and pull out the attributes from the graphic.
Thank you very much!
Chris
NimeshJarecha
Great! Glad to know that you got what you wanted! 🙂
Regards,
Nimesh
