Syntax Error When Attempting to Add Custom Toolbox to Python Script
1793
05-14-2012 05:29 AM
JeffAdams
I am trying to add a custom toolbox to a python script. Seems like a pretty simple coding exercise, but I am getting an incorrect syntax error.
The code I am using is as follows:
#Import modules
import sys, os, arcpy, string
arcpy.ImportToolbox("C:/Data/Custom Tools.tbx", "custom")
Any thoughts? I am running ArcGIS Desktop 10 (service pack 4) with licensing for ArcMap and Spatial Analyst. Do you need full ArcGIS
licensing to add a a toolbox to a python script? Thanks...
Jeff
DanPatterson_Retired
It might be the space in the toolbox name.
MathewCoyle
Honored Contributor
Are you getting an error on your toolbox import or when you try to execute tools from the toolbox?
JeffAdams
Thanks for the response. I had tried renaming the toolbox without spaces, no luck...
JeffAdams
I have this code (single task of trying to load a toolbox) attached to a script that I run from a toolbox. The error appears a few seconds or so after I hit the run button of the script tool. The tool appears to be giving it a go, but then produces the invalid syntax error. I have tried loading a custom toolbox (as in my example) and an ArcGIS toolbox, no luck.
