IndexError: list index out of range
7512
7
05-08-2012 09:27 AM
JoanBiediger
I am new to Python programming and I am trying to see if a working directory is there and if not create it.  I keep getting the following error IndexError: list index out of range.  Not sure what I am doing wrong.
I would appreciate it if anyone can lend some assistance.
import string, sys, shutil, glob, os, arcpy  #print sys.argv  print arcpy.CheckOutExtension("Spatial") from arcpy.sa import * arcpy.env.overwriteOutput = True  #check to see if scratch directory exists: if os.path.isdir(sys.argv[1] + "/working")<> True:     arcpy.CreateArcInfoWorkspace_management(sys.argv[1], "working")      if os.path.isdir(sys.argv[1] + "/output")<> True:     arcpy.CreateArcInfoWorkspace_management(sys.argv[1], "output") arcpy.AddMessage ("Output workspace created")  arcpy.env.workspace = sys.argv[1]
curtvprice
what I really want to do is see if a folder exists in the same folder as the script and if
it doesn't then create the folder.
sys.argv[0] is the path of the script. I think this is what you're trying to do:
import sys import os import arcpy  # create a scratch folder in the same folder as the script Here = os.path.dirname(sys.argv[0]) if not arcpy.exists(os.path.join(Here,"working"):     arcpy.CreateArcInfoWorkspace_management(Here, "working")
MathewCoyle
Honored Contributor
I'd suspect, based on your code, that you only have one argument passing to your script. In that case you would want sys.argv[0]. In Python, as in most computer languages, counting starts at 0.
BruceNielsen
sys.argv[0] should be the name of the script. sys.argv[1] would be the first parameter. This is different than GetParameterAsText.
Joan,
Unless you're going to be working with Arc/INFO coverages, you probably don't want to use CreateArcInfoWorkspace. Use os.mkdir to create a directory for storing shapefiles, or CreateFileGDB for a file geodatabase.
MathewCoyle
Honored Contributor
Joan,
Ah that's right. The only time I've used sys.argv I was doing processing using the script name as an input, that's probably how I got turned around.
DarrenWiens2
Might sound silly, but the only thing I can think of is that you haven't entered a value for the parameter, sys.argv[1]. Have you (ie. when you run the script, do you indicate which folder you want?)?
Does this work? It should.
import arcpy, sys
arcpy.AddMessage(sys.argv[1])
print(sys.argv[1])
JoanBiediger
Hi Darren,
I think you are right, when I print the sys.argv[1] I am getting the folder and the name of the script when what I really want to do is see if a folder exists in the same folder as the script and if
Thanks for your response, I'll keep working on it.
curtvprice
JoanBiediger
Hi Curtis,
Thanks for your help, that did the trick.
