Changing Color of Text In Texbox with Python
1979
05-04-2012 04:31 PM
CharlesGant
Is this possible?  I need to be able to dynamically change the color of text in a text rectangle with python.  I know I can use textelement.text to change the text, but can you use that somehow maybe with RGB values to change the color also?
CharlesGant
Nevermind.  I figured it out.
elm.text = '<CLR red="25" green="55" blue="255">' + newtext + '</CLR>'
JeffBarrette
That is great that you figured this out.  Using tags is really the only way to modify individual text properties on a layout.  At 10.1 we did add fontSize but that is it.
Jeff
