Zoom To Layer (VBA)
2131
7
05-04-2012 09:08 AM
JoelMadero
Hi All,
Let me start by saying I have never coded in GIS programs before, I know basic, some C/C++, and a few others I've dabbled in.
What I'm looking for is how would I go about automating a query on a layer, zoom to the layer, change a number that is on the map (MAP # which is based on a field that is located in the zoomed to layer), then print it. For the last couple years I've had to manually print out hundreds of maps for this project and I think it can be automated relatively easily.
Thanks in advance 🙂
EDIT:
I think doing this one step at a time would be best. So how do I just zoom to a layer, I have this:
Sub Multiple_Polls()
Dim pDoc As IMxDocument
Set pDoc = ThisDocument
Dim pMap As IMap
Set pMap = pDoc.FocusMap
Dim pLayer As IFeatureLayer
Dim pFSel As IFeatureSelection
Set pLayer = pMap.Layer(3)
Set pFSel = pLayer
'Get the selected features
Dim pSelSet As ISelectionSet
Set pSelSet = pFSel.SelectionSet
Dim pEnumGeom As IEnumGeometry
Dim pEnumGeomBind As IEnumGeometryBind
Set pEnumGeom = New EnumFeatureGeometry
Set pEnumGeomBind = pEnumGeom
pEnumGeomBind.BindGeometrySource Nothing, pSelSet
Dim pGeomFactory As IGeometryFactory
Set pGeomFactory = New GeometryEnvironment
Dim pGeom As IGeometry
Set pGeom = pGeomFactory.CreateGeometryFromEnumerator(pEnumGeom)
pDoc.ActiveView.Extent = pGeom.Envelope
pDoc.ActiveView.Refresh
End Sub
But how do I set the correct layer, I changed this line:
to different numbers but all just seem to refresh the map, not actually zoom to layer. Thanks in advance
waleedelmarimi
It seems that what would do the trick for you is using the Data Driven Pages:
1- Activate the Data Driven Pages toolbar
2- Click the Data Driven Page setup button on the very left toolbar.
3- Choose the feature layer you'll use
4- Control the zoom (or scale) under the second tab "Data Driven Scale"
[ATTACH=CONFIG]14105[/ATTACH]
5- Use Dynamic text to display map specific info such as Map#, page#
As for the query part, it's not clear to me what you need to do, so I'll wait for an example of what you need to accomplish.
Hope this helps you.
JoelMadero
Thanks for the reply, I'll give a bit more detail:
What we have are consolidation #'s that are polygons. Currently the manual method of printing is to query a consolidation #, right click on the layer, zoom to the layer (which then zooms to the queried polygon only), then we manually change the Consolidation # that is on the page (just straight text), then we print.
Furthermore each map is actually two consolidation #'s. So I actually query both consolidations, zoom to them, then I print two identical maps just with the consolidation # changed in the upper right corner of the map.
JeffBarrette
Have you considered using arcpy.mapping?  It is a great substitute for many common tasks and can accomplish what you are trying to do.
You can change query definitions on a layer using the layer object:
http://help.arcgis.com/en/arcgisdesktop/10.0/help/index.html#/Layer/00s300000008000000/
For good resources on how to get started, check out:
http://blogs.esri.com/esri/arcgis/2011/09/30/new-resources-available-for-getting-started-with-python...
Jeff
JoelMadero
Jeff
I work for the gov't and because of that it's virtually impossible to convince IT that I need additional components installed and if I do it'll take months of hassle. Does arcpy.mapping require installation of something python related or is it defaulted in the ARCMap install?
JakeSkinner
Esri Esteemed Contributor
Python and the arcpy module are installed by default with ArcGIS Desktop.
JoelMadero
Thank you much! So where I am now, I have figured out the zoom to feature but I have only figured out zoom to selected, not zoom to queried. I can probably work with this BUT if possible I'd like to at least know if it's possible to zoom to queried. This is the same as right click on layer -> zoom to layer. This automatically zooms to queried layer. Thanks again, making progress 🙂
JeffBarrette
You can do this two ways.
mxd = arcpy.mapping.MapDocument("current")
df = arcpy.mapping.ListDataFrames(mxd, "Layers")[0]
lyr = arcpy.mapping.ListLayers(mxd, "myLayer")[0]
#Zoom to all selected features in data frame
df.zoomToSelectedFeatures()
#Zoom to selected features for a specific layer.
df.extent = lyr.getSelectedExtent()
arcpy.RefreshActiveView()
Jeff
