Calculating field, pad zeros to a max field width of 6
7782
8
05-02-2012 11:45 AM
MichaelMiller2
I am trying to calculate a field value so that I pad 0's to the existing values to a max width of 6 chars.
Being a python newbie, I'm a little shaky with coding. I've started with the following code and getting nowhere. Any help/direction is appreciated
arcpy.CalculateField_management(outCrash, "Segment_Code", !Segment_Code!.ljust(!Segment_Code!,6,0), "PYTHON")
Michael Miller
MathewCoyle
Honored Contributor
Sorry to be a pest with this simple task, but still not working. Appears that is is treating the expression as the field.......confused.
It now returns the following error:
ERROR 000728: Field str(!Segment_Code!).zfill(6) does not exist within table
Failed to execute (CalculateField).
You are using the wrong syntax. Check your tool documentation here. http://help.arcgis.com/en/arcgisdesktop/10.0/help/index.html#//00170000004m000000
The expression is the third variable passed to the tool, the field is the second.
DarrenWiens2
Calculator Expression:
MichaelMiller2
Thanks Darren.
It's now returning a syntax error.......invalid syntax on the exp=.... line.
            exp = str(!Segment_Code!).zfill(6)
            arcpy.CalculateField_management(outCrash, exp, "PYTHON")
DarrenWiens2
I think you just need quotes:
exp = "str(!Segment_Code!).zfill(6)"
MichaelMiller2
MathewCoyle
Honored Contributor
MichaelMiller2
Duh.....Thanks for pointing that out Mathew.
Michael
MichaelMiller2
Thanks for the suggestions Darren. The script now runs, but is not adding the 0's to the left side of the Segment_Code values. Any gotchas that I'm missing here?
Michael
MichaelMiller2
Michael
Just discovered the Segment_Code field was converted to numeric during the TableToTable conversion. Looks like I'll have to figure out a method to preserve the string field type before I can pad the 0's.
Thanks all for the help.
Michael
