Converting Excel files to GDB question
2149
05-01-2012 10:22 AM
MichaelMiller2
What is the proper method of accessing excel files using Python?
I'm using the below code and it returns the following error message:
ERROR 000732: Input Rows: Dataset 2005.xlsx does not exist or is not supported
Failed to execute (TableToTable).
import arcpy import os arcpy.env.overwriteOutput = 1 arcpy.env.workspace = r"\\itdhq1apt50\GIS_Data\Test_MM\KellyRawCrash" for file in arcpy.ListFiles("*.xlsx"):     outBase, outExt = os.path.splitext(file)     outCrash = "Crash" + outBase     print file     print outCrash     arcpy.TableToTable_conversion(file, gdb_loc, outCrash)
Michael Miller
MathewCoyle
Honored Contributor
Here's an example of something close to what I do. Each sheet is it's own table.
import arcpy, os arcpy.env.workspace = r"C:\GIS\xlsxTest" outPath = r"C:\GIS\xlsxTest\output" fileList = arcpy.ListFiles("*.xlsx") for file in fileList:     arcpy.env.workspace = os.path.join(r"C:\GIS\xlsxTest", file)     tabList = arcpy.ListTables()      # Convert excel to DBF     tabNum = 0     for tab in tabList:         tabNum += 1         arcpy.TableToTable_conversion(tab, outPath, "Table"+tabNum+".dbf")
MathewCoyle
Honored Contributor
MichaelMiller2
import arcpy, os
    tabNum = 0
    for tab in tabList:
        tabNum += 1
Thanks Matthew, that gets me over the hump.
Michael
