Text Element - New Line
641
04-25-2012 03:22 PM
ShaunWeston
I have a text element in a map document that I would like to update from a Python tool in ArcMap/ArcCatalog, however I'm having trouble getting the text to go to a new line.
So this works fine if I write this in the code like this for example:
notesMap = "Note: Cadastral boundaries are indicative only. \nThis Council provides no warranties \nin terms of property boundaries."
This updates the text element with \n starting a new line
However when I change it to this:
notesMap = arcpy.GetParameterAsText(0)
and put that text in a python tool in a toolbox, it does not read the \n bits and just add them into the text element instead of jumping to a new line?
JasonScheirer
Esri Alum
You can use
arcpy.GetParameterAsText(0).replace('\\n', '\r\n')
to get the proper line breaks.
JasonScheirer
Esri Alum
You can use
ShaunWeston
Ah awesome that does it! Thanks heaps for that Jason.
