How to program "share a line segment with" functionality of Select by Location
2809
10
04-23-2012 11:31 AM
USFS_AGOLAdministrator
Hello all,
I have created a tool which finds the second largest polygon in a selectionset, and eliminates a polygon to the second largest polygon, instead of the largest polygon, as the native eliminate tool does in ArcMap.  In the Select By Location form, it gives you the option of selecting between several different Spatial selection methods, of which "Target layer features share a line segment with the source layer feature" is one of them.  I have written the following code:
Dim pSF As ISpatialFilter             pSF.Geometry = pFeat.Shape             pSF.SpatialRel = esriSpatialRelEnum.esriSpatialRelIntersects
It seems the ISpatialFilter interface does not give the ability to select features that share a line segment.  It gives the ability to do a bunch of other things, but selecting features that share a line segment is not one of them.  Is there another interface I'm missing somewhere that does give that functionality?
LanceShipman
The GP tool arcpy.SelectLayerByLocation_management (Select Layer By Location in the toolbox) supports this query. It can be used from python or from .NET.
LanceShipman
Lance,
The first code block below is how I currently have the code set up.  The second code block is my attempt at fixing it.  Since there is no "esriSpatialRelEnum.esriSpatialRelSharesALineSegmentWith" functionality, I attempted doing it using a gp tool, as you suggested.  Am I on the right track?
While Not pFeat Is Nothing
                    comReleaser.ManageLifetime(pFeat)
                    nNumAdjacent = 0
                    nCurRecNo = nCurRecNo + 1
                    'MsgBox(pFeat.OID)
                    With pSpFltr
                        .Geometry = pFeat.Shape 'EDGAR pPolygon
                        .SpatialRel = esriSpatialRelEnum.esriSpatialRelTouches
                        .OutputSpatialReference("Shape") = pSpRef   'm_pfc.Fields.Field(nShpFieldNDX).GeometryDef.SpatialReference
                        .SubFields = "Shape"
                        .GeometryField = "Shape"
                    End With
                    Dim intFeatCount As Integer = m_pfc.FeatureCount(pSpFltr)
                    'MsgBox(intFeatCount)
                    pFeat.Value(lFld) = intFeatCount
                    pFeatCur.UpdateFeature(pFeat)
                    'pFeat.Store()
                    My.ArcMap.Application.StatusBar.Message(0) = nCurRecNo.ToString & "/" & n.ToString & " records complete."
                    Me.ProgressBar1.Value = nCurRecNo
                    GC.Collect()
                    GC.WaitForPendingFinalizers()
                    Marshal.ReleaseComObject(pFeat)
                    'comReleaser.ReleaseCOMObject(pFeat)
                    pFeat = pFeatCur.NextFeature
                    Application.DoEvents()
                End While
Dim gp As IGeoProcessor = New GeoProcessor
          Dim strParam As IVariantArray = New VarArray
          gp.OverwriteOutput = True
          gp.SetEnvironmentValue("Workspace", m_gdbPath)
          'set the parameters for the select layer by location tool
          strParam.Add(pNewFLayer.Name)
          strParam.Add("SHARE_A_LINE_SEGMENT_WITH")
          'execute the select layer by location tool
          Dim results As IGeoProcessorResult = CType(gp.Execute("SelectLayerByLocation_Management",strParam, Nothing), IGeoProcessorResult)
          If results.Status <> ESRI.ArcGIS.esriSystem.esriJobStatus.esriJobSucceeded Then
               MsgBox("Failed to execute select by layer!", MsgBoxStyle.Information, "frmSelectLayer_btnRun_click")
               results = Nothing
               gp = Nothing
               Exit Sub
          End If
          gp = Nothing
This is the code that worked.  This assumes a feature is already selected before this code is run.  Other parts of my code loops through each feature of the layer, selects it, does a select by location on it, and returns the number of neighboring polygons for each feature in the layer.
        strParam.Add(m_pFLay.Name)
        Dim results As IGeoProcessorResult = CType(gp.Execute("SelectLayerByLocation_Management", strParam, Nothing), IGeoProcessorResult)
            results = Nothing
            gp = Nothing
            Exit Sub
        End If
LanceShipman
Looks good. Are you getting the results that you expect?
Well, I'm trying to figure out how to select the feature in the feature class.  My original code, in the first code block of this post, is looping through each feature in the layer.  But in order for it to do the select by location on only that feature, it has to be selected.  So I'm trying to figure out how to select each feature as it loops through, so it can do the select by location on each feature, and return to me the number of neighboring polygons each feature has.
Hopefully I'm getting a little closer.  Here's my latest code.  It is selecting all features in the feature class at the same time, not just the ones that share a line segment with the selected polygon.  Can you see where I'm going wrong?
Dim pQF As IQueryFilter = New QueryFilter
        Dim pMxDoc As IMxDocument = My.ArcMap.Document
        Dim pActView As IActiveView = pMxDoc.ActiveView
                    '----------------test changes--------------------------------
             pQF.WhereClause = "OBJECTID = " & pFeat.OID
             Dim pSel As ISelectionSet = m_pFLay.FeatureClass.Select(pQF, esriSelectionType.esriSelectionTypeSnapshot, esriSelectionOption.esriSelectionOptionNormal, pWorkspace)
             pMxDoc.CurrentContentsView.Refresh(Nothing)
             pActView.PartialRefresh(esriViewDrawPhase.esriViewGeoSelection, Nothing, Nothing)
                   results = Nothing
                   gp = Nothing
                   Exit Sub
             End If
     end while
'-----------------end test changes----------------------------------------------
LanceShipman
What results are you getting? Error message?
It is not throwing an error message at all.  It is correctly selecting each feature as it loops through, but then when I try to get it to select the neighboring polygons that share a border, it selects everything in the layer.  No errors returned.
Here is the final code, which works great.  The next thing to check into is speed.  I think doing an actual selection on the layer, and displaying it will slow it down greatly.  But for now, it works.
                    Dim pSel As ISelectionSet = m_pFLay.FeatureClass.Select(pQF, esriSelectionType.esriSelectionTypeIDSet, esriSelectionOption.esriSelectionOptionNormal, pWorkspace)
                    strParam.Add("NEW_SELECTION")
                    strParam.Add(pQF.WhereClause)
                    ''execute the select layer by attribute tool
                    Dim results2 As IGeoProcessorResult = CType(gp.Execute("SelectLayerByAttribute_Management", strParam, Nothing), IGeoProcessorResult)
                    If results2.Status <> ESRI.ArcGIS.esriSystem.esriJobStatus.esriJobSucceeded Then
                        MsgBox("Failed to execute select by attribute!", MsgBoxStyle.Information, "frmSelectLayer_btnRun_click")
                        results2 = Nothing
                        gp = Nothing
                        Exit Sub
                    End If
                    pMxDoc.ActiveView.Refresh()
                    'now execute the select layer by location tool
                    strParam.RemoveAll()
                    strParam.Add("")
                    strParam.Add("")
                    ''execute the select layer by location tool
                        results = Nothing
                        gp = Nothing
                        Exit Sub
                    End If
                    Dim results3 As IGeoProcessorResult = CType(gp.Execute("GetCount_Management", strParam, Nothing), IGeoProcessorResult)
                    'MsgBox(results3)
